- Joined
- Nov 6, 2015
- Messages
- 30
- Country
- TomTom Model(s)
- TOM TOM 1005 CAMPER
TomTom 6200 Question
Hi
Iāve had my TomTom 6200 around 8 years now, regularly updated, the battery has been rubbish and the device wonāt work without keeping it plugged in, but in the last 4 weeks it just keeps randomly restarting itself, I had a brand new battery fitted, used a few different USB cables, including the quote long original cable and Iāve factory reset it 5 times! Still randomly restarting itself!
Yesterday I went back to using the original mount and plugged it into my vehicle, but it still kept restarting, but then I noticed something! All the time itās been restarting, itās been plugged into this Spigen brand cigarette lighter adaptor
I swapped it with this dual TomTom adapter and now fine, no restarting! why would this Spigen adapter cause the issue? Or maybe itās just not been recharging my device properly? Even though it has the symbol on the sat nav saying it is charging on the screen, I want to charge my iPhone and the TomTom device at the same time (hence been using this Spigen adaptor)
Is there a ādual socketā adaptor I can buy to charge my 6200 device via USB A supplied cable, but also has USB C on it to charge my iPhone 15 Pro Max at the same time?
Hi
