Please help. one XL question.
Does anyone know how to put your own pictures onto the tom tom one XL? I read the help they offered, but still am not sure what I'm doing. Any help would be appreciated. Thanks.
Do you want to just view it (like in a slideshow) or have it as your startup image?
For the startup image, you'll need a *bmp file. See my following instructions
(NOTE: the image size you will need for the XL is 480 x 272 pixels instead of 320 pixels x 240 pixels ):
>>> Custom Startup Image <<<
To install an image viewer, you'll need a *.jpg file. See my following instructions:
>>> Image Viewer <<<
