Ok, before my 910 crapped out I went to the European store and bought the 710 map for North America. After installation I copied the North_America folder to my hard drive. I have the original file I downloaded and the installed folder.
I just got the 910 back with the 6.5 map. When I try to upgrade the map, home won't let me because of device incompatibility. It sees it on my hard drive but I can't click on "Add."
I copied the installed folder to the TT but it won't recognize it. I'm guessing I need some kind of configuration file in the root directory. Does anyone know a way to get this installed? Or does anyone with 710 installed on the 910 have the correct file I need? Thanks!
