Received my new battery and was trying to change it when , while using Candersons detailed instructions, I ran into the part where you remove the Mic wire connector as to separate the two parts. I was concerned if you pull up on the white plug or what. I did put a little pressure pulling upwards but it felt pretty solid and didn't want to break anything so thought I might get conformation as to pulling it out...Any comments? Thanks
(This referrers to step #3 in Candersons instructions)
