I changed the battery and somehow there's a slight break in the screen display ribbon cable. Now I have a device with no display but has power. Since I can no longer upgrade to a newer Tomtom model I stuck going with another brand of GPS. In planner I can see My Places. If I select DOWNLOAD YOUR DATA I get a UserData.json file.
How do I export/extract My Places to a GPX (Garmin) file? I'm assuming that's how My Places gets imported to a Garmin.
My POI list does not contain My Places.. I'm hoping there's a solution - thanks.
