I'm on my second 540tm and this one has worked flawlessly for the last month. Today it was working fine sound and all then I turned on the car and the unit and no sound. If you really listen or put your ear to the speaker you can hear it a little but sounds muffled. The volume settings all look ok. Not sure what happened? Any advice?
