just downloaded the monroe voice and unzipped it, now I 3 files where do I put them, and how do I install them
Thanks is there a skicky for noobs on how to customize?
I am new to this. I just downloaded Monroe. I extracted all the files in the zip file to the voices directlry directly on my TomTom One. When I go to preferences, and list voices Monroe doesn't show up. Is there an install that has to be done? Do voices have to be loaded through TomTom home?
Bill
i have been trying to do this on my xl and the voices don't show up on my tomtom or on tomtom home. what am i doing wrong?use windows exeplorer, click my computer, tomtom, then click voices and drag them there. Good luck
well, i unzipped to my desktop and then dragged the folder over to my tomtom voice folder and dropped it in there. try dropping it as a folder as well as individual files. they should be there, but when i look at tomtom home list of voices it isn't there, nor is it on the tomtom.
