Using SD card
Have read post and what little comes with the TomTom One on SD cards.
I plan on getting a 2 gig. Can you use it just for storage of routes and load them into memory as needed? And also could they be used with GE and Tyre. Like save the files from Tyre on them and then load them into the TomTom?
Or is it required to load the complete map and operating system onto it.
Thanks.
Christoffel
