I really like the Proclip too. I'm very happy with my purchase, just wish it was a little cheaperi really like the "pro clip"
where can you get one ?
Yes, I have. I've had to adjust it probably twice because it would go loose.Does anyone notice over time, the swivel gets loose no matter how tight the screw is?
Here it the link - www.proclipusa.com
Thanks for the link , they are very expensive but will make the install look very clean
