Tomtom ONE help?
Hi, ive accidentally wiped off my memory card on tomtom one N14644 anyone know where i can download and reinstall them?
Ive tried tomtom home and it doesn't recognize the device?
Have you got a backup of the card on your computer taken using Home or Windows explorer? if you have re-install it to the card, if not then I am afraid its going to cost money to re-purchase a map for the device, exerything else can be downloaded/ added to the device using Home or Windows Explorer - Mike
