I have a Rider 2 I purchased last year and have only used a few times. On my last ride, the unit died on me. It had ben raining lightly for about 230 miles or so. When I removed the unit fron the bike mount I discovered that the connector on the back of the unit was soaked.
When I opened the access dor to the SD card and charging port and also discovered that rain had entered the unit. Upon further examination I noticed 2 small crack on the body of the unit where the latching mechanism tab locks the door to the body of the unit.
I dried the unit and reset it. It operated fine until it got wet again.
The material is very thin there and is obviously a design flaw.
Has anyone else had this issue and how did TomTom respond? I plan on contacting them but I think they will try to weassel their way out of replacing my unit?
Norsk62
Norsk62
