Product code
The 'Product Code' is really the map code. Fortunately, you will probably never need it, as the map is already 'bonded' to your unit.
To get it, you will have to beg and grovel before TomTom officials and convince them that you are not a thief. Probably providing them with you receipt of purchase will do the trick.
