No Product Code - need to buy europe map though, HOW???
Discussion in 'Maps and Routing' started by welch9, May 19, 2009.
  1. welch9
    welch9
    May 19, 2009
    2
    0
    Hi All
    I have a tomtom one version 2 with just uk/ie maps on. I need to buy either a new sd card with the new western europe and central europe map on or I will pay and download it off tomtom.com.
    Problem is i'm reading alot about needing a device code, my problem is I bought the unit used to replace one I had stolen and have no codes/paperwork for it.
    So am guessing if I try to buy the maps its no good, or can i find the code somewhere?
    #1
    1. Advertisements
  2. welch9
    dhn Moderator
    Oct 1, 2007
    23,089
    448
    Toronto Canada
    TomTom Model(s):
    1535 LIVE; Via 1605; Go 50; Go 520
    You should be able to register your unit with tomtom.com using an email address and password.
    Once the account is set up, you should be able to use Home to Add Maps and you should see the map you want available for purchase. No product code would be necessary.
    dhn, May 19, 2009
    #2
    1. Advertisements
  3. welch9
    welch9
    May 19, 2009
    2
    0
    done that cheers.
    Problem is when i get to the add maps page it offers me no other maps whatsoever
    It only offers me an update of my current map
    I desperatly need w & c europe by friday, otherwise i will have to go out and buy a new one
    #3
  4. welch9
    46jimbo
    Dec 4, 2006
    1,020
    65
    Toronto, ON
    TomTom Model(s):
    TT ONE v1
    Under 'Change preferences', go in several pages and select 'Show version'. Your device code is on the first line.
    (If you can't locate 'Show version', make sure that you have selected 'Show ALL menu options'.)
    46jimbo, May 20, 2009
    #4
  5. welch9
    mvl Moderator
    Dec 19, 2008
    5,433
    61
    Boston, MA, USA
    TomTom Model(s):
    GO 2535 LIVE, GO 1535 LIVE, GO 740 LIVE, Go 930
    Have you updated your application in tomtom HOME to 7.903? That's the minimum requirement for any of the new maps.
    Also, try putting a blank 2gb sd card in the ONE, and let HOME download applications 7.903 fresh. Maybe it needs more space on the SD before offering maps to you.
    mvl, May 23, 2009
    #5
    1. Advertisements
You'll need to choose a username for the site, which only take a couple of moments (here). After that, you can post your question and our members will help you out.
