Need Help!!
Ok I last used my TT1 two days ago and all was fine! Today I go to turn it on and nothing.:confused:
So Im assuming the battery is dead. Off i go to plug it in and the green light comes on.... Press the button and Bam. Nothing happens! :(
Has anybody else had this problem?
If this is common and a dumb newbie question then i apologize now!
Thanks, Paul.
Probably is dead and you need time to charge the device. Give it about an hour and that should be enough charge to at least turn it on.
If not, you can try removing the SD card (if you have one), reset the unit, insert the SD card (again, if you have one) and try powring it on.
