Need help with TTOne & TMobile Dash
Yall
I am on the end of the rope here. I tried to pair my TT1 with my Dash for traffic, cameras and the likes but after the initial screen it comes back with the message saying The required features could not be found for this phone.
Does anyone out there knows what I have to do in order to pair these devices?
ARosenthal:confused:
TT and Tmobile Dash
Here is what I did (I have a 920). The hardest part is getting the registry hacked to enable DUN (dial up networking).
* TomTom tested- 920 T
* Wireless carrier - Tmobile
* Grandfathered 20.00/month data plan
* Tmobile Dash with Windows Mobile 6
Which features work
* Handsfree -Check
* Phonebook transfer -Check
* SMS messaging (Cannot get this to work, always grey'd out)
* Data transfer -Check
I did have to hack the Dash to enable DUN, and then do a manual config for the TT to see the Dash data.
I used this article
Here are the manual settings I used on the TT:
APN: wap.voicestream.com
Username:
Password:
Dial: *99#
Connection string: AT+CGDCONT=1,"IP","wap.voicestream.com" (it said case sensitive, I used default)
