Installation Questions
Status
Not open for further replies.
Winnipeg
<img src="/styles/default/custom/flags/ca.png" alt="Canada" /> Canada
Via 1535 TM
Hi
If I install a new 845 map (say Canada or the US) does that new map erase the existing older map and take it's place in the internal memory?
Also, where are the maps stored? I assume they must be in the internal memory when it came from the factory because the Canada and US were on it and I didn't have an SD card installed.
I have a GO 630, can anyone direct me to the procedure or where to find it for installing a new map? Thanks for any answers!
Replied in the other thread where you posted the question. Locking this one.
Status
