I downloaded startup and shutdown screens for my 730 Go, the startup screen comes on fine but when I shutdown the Go the default screen shows up instead of the one I downloaded. Any help would be appreciated.
Sorry that dosnt work. I downloaded the shutdown screen directly from TomTom home 2.4 Click Add Images and Icon,Then shutdown images. It does a self install. Worked for the startup but not the shutdown.
I believe to see the shutdown image, you have to check off the choice for showing the warning not to leave the unit in the car. It's under preferences-->safety.
