720 help screen popup
Pittsburgh Pa USA
TomTom 720
Every time I choose to navagate to a address I get a help pop up menue about using a zip code or when it is time to put or say house number I get the help screen popup about something about using a button on the bottom to make it easier.
I have the help menu turned off already and have turned it on then off and rebooted many times..
Anybody else have this problem.:confused:
Maybe I have them turned on as I changed the settings and they seem to not pop up not. Man I am tired.
