Would it be possible to make the volume of Navigator application adjustable. The default volume is way too LOUD. I like to listen to podcasts at the same time as I'm navigating. As it is, either the podcast is too soft or TomTom is too loud.
Making the volume adjustable (instead of simply having the 'mute' option) would solve this issue.
Thank you,
- rob
Thank you,
- rob
