Using Go 2505 While Plugged in to PC
Is it possible to use the GO 2505TM while it's connected to my PC's USB port like you can with the older TomTom's (Go 740 or XL 340TM for example)? Or does the GO 2505TM work like nearly all Garmin's do when they're plugged into USB?
Once you plug the 2505 into the computer, it'll automatically open up the web based MyHome page. But there is no emulator (Operate my Unit) on that page.
Yes, (unless you are in the process of getting a download from TT), I believe you can still operate the unit, but I have to ask why you'd want to? Is the battery running low?
If not, you can operate it without having a connection to the computer.
