- Joined
- Jan 9, 2008
- Messages
- 65
Okay, so I really love the TT but there's some problem that seems to recur with my unit:
I've gotten my TT paired with my Sprint Upstage cell phone via bluetooth. This took some work but I finally got it. I also sometimes have my TT transmitting instructions and music through the FM transmitter to my car stereo. Sometimes after I make a call on my phone over the TT , no sounds will come from my unit (to the FM transmitter or to the internal speaker) unless I a)restart my cell phone and have it reconnect to the TT or b) restart my TT and then have it reconnect to my cell phone. It doesn't always happen but when it does happen it is quite annoying as I'm unable to get any voice instructions. When it happens I try and change the speaker settings to output to the internal speaker but nothing comes out even though the volume is turned all the way up.
I have the most recent software updates, the most recent map, and Tripmaster 1.8 and 2.0 beta installed (but the problem occurred before I installed Tripmaster).
Any ideas? Thanks in advance.
