Hi, I've lost the audio function for my TomTom XL-S unit completely for quite sometime now, and I havn't been able to find a fix for this problem. After searching through this forum , it seems that many users suggest that it's a firmware problem and I have to downgrade it back to 7.14 from 7.16. I did exactly that and still can't get the sound/voice to work, the unit used to work perfectly for a few month, I think I updated a long time ago by mistake, and downloaded some other 3rd party voice packs. Well now the GPS works fine, just without the voice.
Can someone help me?
I've tried the following already :
- Downgrading the firmware back to 7.14
- Disable Text to speech and Re-Enable it again
- Try a few other voice files, none of them are working (Jane UK, Susan US, Jate UK etc..)
- Tried copy everything on a 2gb SD card and boot from the SD card, GPS works but still no luck with audio.
- Deleted everything off the SD card and TomTom's built in storage device, still no luck after restoring it back to factory mode.
- Reset the GPS Device
