reset for XXL540S
Guelph, Canada
XXL540S, VIA1605
My GO720 was always requiring me to use the reset button. (Trouble with connecting to the computer). I now have a XXL540S. However there is no reset button. There's nothing. Anyone had a problem yet where they would need to reset. And if so, How do you do it?????
For models such as that, holding the power button for 10-15 seconds does the reset (until you hear the drum sound).
I just purchased the same model a couple weeks ago. Some questions for you...
Did you buy a case for it? Are you using the window mount that came with it?
There are a few 5" GPS cases online if you look hard enough but I've never found one in any store near me. Also, I am unable to use the window mount as my windshield is too far to reach. I reluctantly ordered a vent mount (mixed reviews about these).
You can also consider a friction mount. For my 5" model, my wife got me a Roots camera bag at Blacks that does the job perfectly. Padded and a shoulder strap.
