Please help with my installation
My phone is the Asus P535.
I am trying to install TomTom Navigator 6 on it. I have the map loaded my my SD card but the program can't locate the map. I am wondering what dir do I have to put the map folder in?
I am trying to install TomTom on the SD card but it won't do that either...
very lost...
please help me. thanks in advance
You're instructions should mention to use HOME to install the maps.
Do you have the instructions?
Go to tomtom.com/support and type in manual. it will direct you to the manual. Don't forget to install HOME with the CD it gave you.
