PC Connection Problem - XP vs Win7
Greetings,
My XP machine was out of service for a while and I connected the TomTom to the Win7-64 machine to update. Both have TomTom Home 2.8 ( latest version ). My XL will now only connect with the Win7 machine ( which is NOT the one that I want it to use on a regular basis. )
Has anyone had similar problem or a suggestion as to how to fix this? Thanks! -David
Reset the unit by holding the power button about 10-15 seconds until you hear the drum sounds. Then try connecting to the XP machine.
dhn,
Thanks for the response. I did as you suggested and heard the drums ( that was a new one on me ) but still no connection. The XP machine see the mass storage device, TomTom Home does not ( No Device Connected )
-David
