Hi, I've been having real problems with my ONE IQ Routes Sat Nav, so I thought I'd post on here to see if anyone wiser than myself can help.
My TomTom decided one to start asking me to set the language/left or right handed/which way to display the time, and to set the time. It started doing this out of the blue, I hadn't connected it to a computer to update it in 3 months or more. The next day it began to freeze on the 'set time' screen before rebooting back to the start screen in an odd, frustrating loop.
After trying far too much to post on this forum all together I decided to try something simple that in theory should work as far as I understand it. Here goes:
I have deleted all items from the TomTom ONE IQ Routes, then connected to TomTom HOME and downloaded the application offered, from here I turned the sat nav on. It got
passed the initial 'Logo' screen but on the 'set time' screen froze, and restarted.
So I connected to the computer, told I had an invalid version of the application on my sat nav from here I was offered another application, slightly larger in size. So I installed it.
When my sat nav asked if I wanted to connect to the computer I said yes (as requested by TomTom HOME)
No error message! No more updates to the application, so I disconnect and turn the sat nav on, select the language, tap the screen anywhere to begin, select left-handed operation, select how the time should be displayed and select the time - it freezes and restarts at exactly the same place.
I'm baffled, there shouldn't be an invalid file on this Sat nav as the only files on it are the applications downloaded from TomTom HOME.
Thank you in advance for any help you may be able to give me!
