I want all the POIs that originally came installed in the GO300 and are missing from my new 510. Someone suggested that I just copy the poi.dat file from a GO300 into my 510, but I don't have the GO300 anymore...
So, this is what I need:
You copy your poi.dat onto a CD and send it to me. If the CD has the right file but I am unable to make it work (say, because the poi.dat from a GO300 is incompatible with the 510, per instance), I will paypal you $10 for your time and effort. However, if I am able to use the poi.dat file that you send me, I will instead paypal you $25.
OR, maybe you have a better idea that doesn't involve CDs... Either way, if you get me a solution, I'll give you $25.
Thanks,
R
Thanks,
R
