Need Help Please
Hello i was wondering if the tom tom go910 will make the itinerary u add will it place it in order so u are not going in circles to Ur next destination. Like like adding 10 stops place it to the closest spot first ending with the furthest.,
Man wouldnt that have been nice. I was looking at houses and put all them in then ended up not even using the thing cause i was going in circles. Any gps out there that put them in order>
You can order them the way you like though, meaning moving each item on the list to top or bottom. You of course would have to 'optomize' the route yourself.
