Need Help Please
sab
Montreal, Canada
540M XXL
I convinced a friend of mine to buy a TT 540M like the one I purchased. He's not to handy with tech stuff so he asked if I could update his unit. Took it home, entered the Lifetime maps code and as the map was being installed to internal memort the USB wire was accidentally unplugged.
When I turn the unit on now it says no map found and if I connect to home it just keeps searching for an update but after an hour and a half no luck. I didn't make a back up of his unit before I started :mad:.
Anything I can do??
Thanks in advance.
Just noticed on the website that TT says to delete map folder from unit and then try to update it. I'll give that a try first.
