I need some help....I'm new to TT......so if this has been addressed b4 bear with me....anyway...when I try to use the "MyOne" on the TThome it says to activate my map...so I put in all the codes.....product code....activation code(that I got at ttcode.com) and it says that the code is not valid....has this happened to anyone else..or does anyone know how to fix it????
Thanx in advance
oly
Thanx in advance
oly
