IQ roubting help turning on
Pittsburgh Pa USA
TomTom 720
How do I turn on the IQ routing. I have 8.302 and map 8.25 and I am reading about the IQ routing being turned on. I cannot find this option on my 720. Where is it at?
Planning preferences.....................The screen where you select 'fastest', 'shortest', etc.
Yes when you go to the planning preference icon and you press this the next page will be to check for esample fastest routes but below on this same page is an IQ Routes button.. Press this and then the next page place a dot on enable. Good luck
