iPhone case vs. Car Kit
Atlanta GA
iPhone app
Has anybody found an iPhone case/skin that would fit into a car kit without jamming or breaking it?
TIA
I use a Zagg Shield on both my iPhone and the wifes, no problem with the car kit as its so thin and clear you don't even know its got anything applied, bit of a fiddle to fit though, the front is easy but the rear which also covers the sides is a real labour of love to apply correctly - Mike
