Help with charging
Hi, looking for a little help, i have a 710 which is nearly flat. When its in the home dock and the car dock the green light comes on but it isnt charging its now virtually flat. Has any one else had this problem if so what is the solution. Its not in warrenty.
Regards
Well, you can replace the battery. See here:
[ame]http://www.youtube.com/watch?v=ncBUnxMbyS8[/ame]
Or, try googling 'satnav repair shops in UK'
