help please!!
I just got tomtom6 a couple days ago, and installed TThome on my computer... The first day, it recognized my PDA (a sprint mogul), but since then, nothing.
I'm trying to install some voice packs, but I absolutely cannot get the PC to recognize my PDA... anyone got any advice?
Is there a way to manually install the voices? i've tried copying the data files into the voice directory, but the program doesn't recognize them...
Any way to make this work?
If you are using Navigator 6, then you should be plugging the SD card directly into your computer via a card reader. Tomtom Home does not talk to the card through your PDA, though I suppose there could be a way to make it work.
Eddy54
