Help Please!
TomTom ONE 3rd Edition
Hi everyone. I'm new here and I don't know what else to do.
I was in the middle of installing updated maps onto my TomTom One 3rd Edition and I got an error message. The Guam map copied but the USA and Canada maps did not. I went back to try to install the USA and Canada map but it says I do not have enough free space on my system. It tells me I must remove some items installed which total 16.3 MB (maps, applications, voices, etc.) and it's telling me I have to remove 693.0 MB of stuff. I'm really confused. How can I fix this problem?
Thanks for your help in advance!
Maybe you are installing something you already have installed? Can you check your One and see what is the latest version of American & Canadian map? It should be 710.1575
Because I beleive that when there is an update, it will self-delete the old to make room for the new automatically--not 100% sure though.
