high to all tomtom users,.my tomtom 130-s lost sattlites two days ago it has great maps .just lost all sattlites.can anyone help? was trying to install a new adress.
Use Explorer to look at the contents of your unit and delete anything you find in the ephem folder.
Now, go here:
C:\Documents and Settings\yourname\My Documents\TomTom\HOME\Downloads\complete\ephemeris\
and delete any sub folders you see there.
Connect the unit to Home and you should be offered a new gpsquickfix file. Install it and see if that helps.
Before doing any of the above, try resetting your unit by holding the power button for about 10-15 seconds, until you hear the drum sounds. See if that helps first....
