Fix for Tripmaster on Rider Navcore 7.54
Updated - Fix for Tripmaster on Rider Navcore 7.54
I updated my Rider and then couldnt see any 3rd party apps in my menus. I think this is common for the latest rider update. Adding a TomTom menu file to the SDKRegistry fixes this problem. The menu in the link below worked for me. Hopefully it will work for you to! Good luck :)
http://home.comcast.net/~spheasant1/TomTom.mnu_LE.zip
See here to keep the original rider preferences (like 'connect to headset')
Basically you just delete all the preferences settings in your TomTom menu file.
eg see attached compared to the one in the first link.
  • TomTom.zip
