I exported some point from Google Earth as KML files. I converted the KML's to OV2 files using TYRE. I copied the new OV2 files to the maps folder (USA_and_Canada).
The POI's show up in the list of POI's but when I select one, I get an error that says "No POI Found."
Any idea what is going on? It also seems like some one or two of them work but others do not. I have tried naming them without spaces (using underscores), shortening the name, and nothing seems to work.
Any ideas? I really would like this to work. I read somewhere that this is a bug with the ONE 3rd Gen. I also read that it could be patched, not easily, but it was possible. I am interested in any solution at this point.
Thanks,
Doug
TomTom ONE 3rd
App: 8.010 OS: 190943
Map: 715.1712
GPS: 1.21 Boot: 5.5001
Thanks,
Doug
TomTom ONE 3rd
Map: 715.1712
