American Map Color Scheme
There should be a folder called schemes.
If there isn't create on and it will pop up on the options.
Connect your unit to your computer.
Explore the device and there should be that folder.
If not right click the back ground and select "new' then 'folder'
Name the folder schemes and place the downloaded schemes there.
After that you will have to go to your tomtom's preference menu and select the option to change schemes. you will find it there.
Duh .... I was not thinking !! I did not understand that you add the folder to the SD card via My Computer, NOT to the My One in TT Home.
That new America scheme is installed and looks great !!
Thanks Pedro and smokiewolf !!
hbytgrik
