I just bought a brand new 920T
Maybe this is a reason as it is brand new? Give it a chance, and make few full-charging cyckles - this can improve the battery performance.
and it shuts down after between 60 and 90 minutes of battery use each time.
I manage with mine 90 to 240 minutes, depending on the temperature, number of route changes (as each time it has to be recalculated), and the number of phone calls made or received during the trip.
Of course, the best results are achieved with the connectivity shut off- the disadventage is that the pilot does not work either.
This TomTom GPS 920T is therefore unusable for long trips, which means for most US buyers.
And that's why it is delivered with the car lighter charger
In Europe they may get away with this poor battery due to on average shorter travel distances there, but not here.
Yhhmm..... Don't know what to say here...
Does it mean that I use my GPS when go to the store 15 minutes away? Believe me, in that case I know the road
Now I am forced to have the lighter of my old car fixed (a few hundred dollars) just to make the TomTom 920T work with the lighter charger.
That way the price of the TomTom GPS 920T is way higher than that of its competitors.
Oh yeah! And imagine this: somebody had bought a competitors' system without having a car. Terrified he finds he can't use it more then 120/ 240/ 360 minutes (depends on advertisement), and he needs to buy a car to charge it while in use! And that makes it cost at least few thousand dollars more! So you are still better off with repairing your lighter
And just BTW- I am sure you can get it done cheaper then that
The advertised 5 hours battery life is simply untrue.
100% you are right! But before I'd believe the technical specs, I would rather ask the question on users' forum, just to find out the truth and avoid disappointment. Based on my experience, the specs state such facts based on labratory conditions, and differ a lot from the daily usage.
Cheers from Poland
Piotr
