720 not connect T-mobile
First - it is not on their compatibility list Also, you did not say what steps you have taken to try to connect it.
Not knowing what you have tried already, I will mention that you have to be sure your Nokia bluetooth setting is set to be discoverable - or it will not let you set up even the basic hands free connection.
However, many other devices do work and your very well may also, but you are going to have to do some homework. There are several threads in this forum on which devices work and also the manual settings to use if the TT wireless installation "wizard' does not get it connected.
Often it is just a matter of using these settings and following the instructions in the forum on using them.
Note - if you have or manage to get it paired for hands-free, but you get a message that the device will not support data services - that will be it, as you cannot even get to the manual settings in that case (like the TMo Samsung behold I am trying out).
