TomTom's specification for the Urban Rider states
Memory
CPU 380 MHz
Memory size 32MB RAM
32MB seeems incredibly small! Can anyone who's got one comment with regard to the ability to upgrade the maps and software, add custom POIs, voices etc.?
The manual also states you have to have at least 5MB free to use the facility to record your route.
It's missing a powered mount (thanks, rcacs) the Scala headset. It doesn't have an expansion slot.
It sounds a massive step backwards. What am I missing?
Memory
CPU 380 MHz
