- Joined
- Dec 21, 2007
- Messages
- 1
Is there any way to get the 920 to turn on with my ignition in the car. I know how to get it to automatically shut off with the ignition but not turn on.
Nobody has found a way to make the unit turn on when you start your car. To make it turn off when power is lost, go to Change Preferences > Battery Saving Preferences. It's not obvious because that screen only has options for when to activate the screen saver. But just pick whichever option you want there (default is Never turn off screen) and hit the Done button. Then you will see a check box that says "Switch off when external power is lost". Touch that box and touch Done.
Kind of bad menu design from TomTom on this one. I don't see why they couldn't have put all the options on one screen.
I have contacted tomtom and they said that this feature will not be added to the 920t because of legal issues? Someone must find a way to get this option to work, it is very annoying having to hold the button for 3 seconds to turn it on!
Maybe this is remotely related to the "how to kill battery thread?"
Maybe they found that the newer models were not well-isolated and hitting them with power when the ignition was turned on caused problems? Or maybe it is a legal issue - they want the driver to be very aware that they are using this device rather than having it blend into the background by automatically starting up.
But I can see that if the TT is installed a bit removed from the driver's position, leaning over or even more exaggerated movements would be a pain to get to the device to press and hold the button down.
I still have not taken mine on a longer trip - in and out of the car a bunch of times and having to fire it back up each time.
I have no problems with this.
The GPS must be removed if parked in a public place as theft is just too rife!
I prefer to have to turn it on myself as I dont like auto on..nothing should be passively draining my battery!
Still nothing on this? I'm on the fence about keeping my 920 because of this. I've gotten over how bad the mounting system is compared to my Garmin Nuvi 770, but this auto power on w/ ignition is something I really want.
