I'm after some help with my TomTom XLIQ.
I havent used it for a couple of months and was ok when I switched it on apart from not seeing any satellites because I was indoors. I thought I would plug it into the PC to see if there were any updates etc and it started to go wrong.
It connected ok, launched the software ok then when I went to update it I got this error:
I have this app already on my drive C so why would it need to install that again anyway?
Since it failed I disconnected the unit and it failed to do anything. I tried to reset it and got as far as what I would call a sort of Bios looking Dos screen but it didn't go any further.
I have tried a few times to boot it but the same things happened again.
If I do a normal five second start it gets as far as the TomTom hands log but then freezes.
Help me please!
Help me please!
