I'm new to this forum. I've looked through and found lots of great posts.
However the problem that led me here, I have not found discussed in my searches of the previous posts. So if there is a discussion, please point me to it.
About a month ago I purchased a TomTom One XL and did the backup of it. Last weekend I decided to hook it up to the PC again and get another backup after using it for a little while, my prefs, etc. At that time, there was a TomTom One application update and a Home update. I ran a backup and performed the updates. After the upgrade I got a screen with a red X on it during bootup. I reapplied the TomTom Application and it seemed okay.
Mid last week I realize that all the default POIs are missing. Gas, Restaurants, Zoo, etc. All of them give me the result 'No POI found!' when I try to find them. My custom POIs and addons work without a problem, including ones that I downloaded via Home.
No problem, I'll just restore the backup. I click through and the restore screen runs for about three minutes and then says complete. Still no joy when I look up a POI.
At this point, I'm at a loss. It's still working to guide me from point A to point B, but no POIs.
Thanks for any advice that you can offer. I'll be calling support this week when I get time, but if I can avoid that I'd prefer to do so.
Chuck
Chuck
