Tom Tom Gods help me
Alright folks, so I think I did an update that made things not so happy....either that or a hit a setting and now I'm confused.
I used to have satellite signal within seconds of booting my TomTom, now it takes anywhere from 2-5 minutes. It is so annoying, does anyone have any ideas?
TomTom info
TomTom ONEv4
App 6.560
GPS 1.21
Boot 5.05
Map USA/CAN 665.1293
Any ideas?
Although I've never experienced it myself yet with my ONE (same version as yours), I did come across a few posts that suggest you hook it up to Tomtom Home on your PC to get the latest satellite "Quickfixes". Many have reported better response time.
I doubt you hit any button/features that would cause this phenomenom.
See I think it is the updates that did it. It downloads the updates every time I connect it, but none have helped.
