I just bought the TomTom one 3rd edition and i was in the process of updating when an unexpected error occured, something about unable to find the requested file type so i went into explorer and found the Removable Disk Drive that was my TomTom, i went into it and accidently right clicked a new folder then my pc froze so i rebooted.
I noticed that my TomTom was playing up, i turned it on, it made the sound with the TomTom logo on then the yellow bar loaded and then it went off ! and its always being doing it since. I can connect it to the pc which is the only way to keep it on, i thought if i could successfully update it then the problem would go away but it seems TomTom home always fails to launch with an error message "Runtime Error!" and asks me to reinstall which I've done twice. I found the folder that i accidentally created when i looked at the Removable disk in explorer and tried to delete it but a message came up saying "Cannot read from source disk" and now I'm stuck and i need desperate help.
