Well I'm pretty disappointed with by brand new XL330 experience so far. Used it going to work yesterday and all was good. Got home and decided to install and use the Home program and get the free upgrade to the USA and Canada map.
It took quite some time to download and about 60 percent through the process the server error-ed out. I resumed the download and in the process of installing the map to the device it error-ed out again... and won't install the map. I have gone through the process of manually installing the downloaded map that I found here.
Disconnected the TT from the computer the proper way and booted the device. Got a message about the activation being needed and it gave me a 10 digit number in two 5 number segments and said to go to TTcode.com. According to TTCode.com it needs to be a 15 digit code in three 5 number segments. Did some more searching around here on the board and reallized I had not copied the .meta.dct file to the map folder on the device.
Went through the whole map copy process one more time (this time copying the .meta.dct file) and I now sit here with the device saying "Problem with map. You cannot use this map on this device: USA_and_Canada."
Anyone have any suggestions?
