I found the suggested deletion files on my desktop in the TT folder. Are these the files to delete with no further change to the TT itself?
Jack
No other changes should be necessary to change on the TT itself; at least I haven't had to do anything else on mine.
Not that you'll need these instructions, but I keep them on my computer "how-to" folder as a reminder the next time I need to update those QuickGPSFix files:
1) Connect your TomTom device, to your PC
2) Browse your TomTom folders using Windows Explorer.
Delete the \ephem folder contents located on your TomTom.
3) Safely disconnect your device from the PC
4) Reset your device following the instructions from TomTom's website
5) On your PC, browse the My Documents\TomTom\
HOME\Download\Complete\ephemeris.
Delete the \ephemeris folder on your computer.
6) On your PC browse the My Documents\TomTom\HOME\FromDevice.
Delete the \FromDevice folder on your computer. (this might never contain anything, but . . .)
7) Open TomTom HOME without the unit connected to the PC
8) Select "Update My Device." When prompted, connect your TomTom to the PC and turn it on. Ignore all errors (including return failure codes or messages prompting to restart your TomTom) by clicking BACK or OK
9) You should now see QuickGPSFix as an option to install as an update. Select it and click INSTALL
