I have a Go510 for 2 months, works fine until last weekend
Now impossible to start it when powered on its own battery, If I put it on the AC charger it works fine and the battery charge indicator tell the battery is fully charged.
It works fine as long as it powered by ac and works with the computer, I updated it to latest version, no problem
I check tomtom FAQ and tried several times to RESET it NO CHANGE
Can some body help?
what is the problem?
How can I fix it?
I tried to contact TomTom Customer support by email several times they never answer
Thanks for help
Francois
Can some body help?
How can I fix it?
Thanks for help
Francois
